PRODUCT DESCRIPTION This build was designed to be a low volume project to showcase what we could do, but due to the requests we received we are going to offer this in limited quantities. The total cost for this product is $1,899. The preorder deposit of $500 will be subtracted from the total cost, and is non-refundable due to the high cost of material that is required to build these products. Once the product is completed and ready for shipment, the remaining balance and actual shipping costs will be invoiced to you. The expected delivery time is around 90 days but depending on sales volume this date may vary depending on when you purchase. This project was born by the idea of CNC milling a full roll cage AND body panels to create a truly over the top RC vehicle! The tube style chassis is fully CNC milled and bolts together in just 5 parts. The hood, grill and side panels are also milled from billet. The only body panel made from sheet metal is the roof panel and number plates. The chassis and body panels take over 100lbs or raw aluminum to complete! Here is what this product consists of and what you need to build your own. What you will receive: CNC Milled Chassis - Driver Side CNC Milled Chassis - Passenger Side CNC Milled Chassis - Front Crossmember/Shock Mount CNC Milled Chassis - Roof CNC Milled Chassis - Rear Crossmember/Shock Mount/Spare Tire holder CNC Milled Driver Side Body Panel CNC Milled Passenger Side Body Panel CNC Milled Hood CNC Milled Grill with Rigid Q-series Light Mounts Laser Cut Rear Number Plate (2) Laser Cut Roof Panel Q-series Lights (Headlights) 5" Rigid Light Bar (For above the windshield, not pictured) 4" Rigid Light Bar (Red LED strip) Ripper Front Bumper Rocker Supports Delrin Rocker Skids Hood Vents (3d Printed) Front Radiator (3d Printed) 40mm 12v brushless fan Battery Box (3d Printed) ESC Mount (3d Printed) Sway Bar Set Stainless Link Kit Hardware What you need to complete a roller (not included): SCX10-2 Chassis rails SCX10-2 RTR skid plate (or original SCX10 skid plate) SCX10 Rear chassis crossmember Axial 3-gear transmission (complete with slipper and spur gear assembly) Axial Bomber Interior Axial Yeti Fuel Cell Axial EXO radiator Vanquish Products SCX10-2 F9 front axle with servo on axle mount SCX10-2 knuckles and kingpin bushings SCX10-2 rear axle of either style (Currie RockJock or F9) SCX10-2 axle internals (gears, shafts, lockers, hexes, etc) SCX10 driveshafts (this truck has a wheelbase slightly longer than the standard 12.3in but most SCX10 compatible driveshafts should work without an issue) 5 - Vanquish 1.9 wheels with 475 hubs (or 350 hubs if using the KMC XD Center Cap) 5 - Tires and foams (max tire size of 4.75in, when using the maximum tire size you will experience some rubbing still) 90mm scale style shocks (up to a 4in shock will work but larger bore shocks may have clearance issues with the rear sway bar) Bearings and hardware All chassis and body panel pieces will come in a dusted anodized finish, similar to what you've seen on many of our parts before. Customers who purchase this product, will be given a discount code for the purchase of the supporting parts that are needed to complete the truck. Note that this car is being milled from high quality aluminum, however nothing is indestructible. It is possible to bend, dent or break these parts still. Also due to the design and machining style used to produce these large tube work like parts, there is still hand work that is done to clean up the parts before plating. Some machining marks may still be visible when completed. There will be some differences between the photos you see above and the final product you will receive. We will be separating the rear number plates off of the side panels. This will make for a more durable side panel design and add a nice depth to the the truck. Source Vanquish Products: http://www.vanquishproducts.com/pre-order-deposit-cnc-milled-ripper-project/
