The Decently Average Honcho
Discussion in 'Crawlers' started by slash 127, Mar 21, 2013.
  1. chaseloc101
    What battery are u using. Does sound like a short. Let us know after your water break.
  2. AK BIGFOOT
    AK BIGFOOT Registered
    GRANTS PASS, OREGON
    I clean my motor every time I go out and get it really muddy or dirty.
  3. slash 127
    Just a 2s 5000 mah lipo
  4. AK BIGFOOT
    GRANTS PASS, OREGON
    I don't mess with lipos, I only run NiMH
  5. slash 127
    I used to but its nice being done and charging whenever you want
  6. chaseloc101
    I run 3s. Gives that power to climb almost anything. I run 2s as back up. I dont bother with nimh anymore their to weak and short life. I do have some for back up too though.
    How exposed where the wire before they melted. Is your esc getting to hot?
  7. slash 127
    It wasn't at all the little rubbery deals were still covering them. But it was set with no drag brake from the factory and that's how I kept it but it was driving like there was a drag brake. But I can spin the tires on the table fairly easily
  8. AK BIGFOOT
    GRANTS PASS, OREGON
    I've never ran Lipos but I should pick one up and try it out.
  9. chaseloc101
    Yeah I left mine factory set too. It helps when climbing down hill. But if u have a brake on your radio. Make sure it is off.
  10. slash 127
    It should be and if not it shouldn't cause the motor to smoke lol
  11. chaseloc101
    What u never ran em before. Oh man. Your truck really comes to life with a lipo. I popped in a 3s in my sc10 for fun yesterday. Couldnt get a max speed the body turned into a parachute and started to lift off and do a backflip. Fun times but had to make it short. Because I balded the tires in 20 seconds.  Oops
  12. AK BIGFOOT
    GRANTS PASS, OREGON
    Yeah I really wanna try lipos but just haven't
  13. chaseloc101
    True unless u binded up on rock or somthing and tried flooring it. I saw a kid do that to a night crawler. But still worked after we looked at it. And the plus side is that these brushed motors are cheap.
  14. chaseloc101
    Yeah my buddy loved his stock slash. Then I told him to get a lipo and a charger. The guy at mild to wild talked him into a 9000 nimh. Which was decent.  Till I showed him what mine did with a mamba max brushless system and just a 4000 2s. His jaw dropped. .lol
  15. slash 127
    Yeah that might be what happened I was in a deep dirt bike rut and it could have bound up. Still runs fine and I have a 35t integy
  16. highlandcrawler
    If its the 20t that's a wraith motor and has reverse timing. When you changed axles and swapped everything around did you change motor direction? I see axial motors smoked all the time from running retarded timing in reverse. Make sure your running the motor in the right direction
  17. slash 127
    Nope its out of a wraith and has only been ran with wraith axles
  18. highlandcrawler
    and you confirmed its running in the correct direction how then? They were wrong in a lot of the wraiths also. That's why so many wraiths burn the stock motors is they are running reverse from the factory on a lot of them.
  19. slash 127
    Hmm maybe how can you tell
  20. slash 127
    No matter how I put the settings on my controller and I hold the motor in my hand the motor has more torque in reverse? I found the problem where my heat issues came from and its the front wheel rubbing the hub
