Project "Ridgecho"
Discussion in 'Crawlers' started by knightrider81, Feb 10, 2013.
  1. slash 127
    Black sidekick
  2. highlandcrawler
    You guys both need your own links. The bent links an ar60 requires don't work properly on a scx10 and wheel base is specific per vehicle so just bolting on links because they fit in a hole doesn't work very well unless you don't care about wheels lining up with wheel wells. Wraith axles are 4 or 3 link compatable only not y link compatable. And they need bent uppers to work right. Don't forget you guys need to trade shocks also. The damping rates and spring rates are very different to deal with the extra leverage of the wide axles. If you run wraith shocks on a scx10 it will be way over dampened and won't have proper preload adjustment. Same holds true in reverse. Wraith axles on scx10 shocks will be overworking them and not work right.
  3. slash 127
    I have scx shocks and wraith shocks and I will probably end up buying a link kit
  4. knightrider81
    hey man sorry im running late im just now leaving my house in rogue river
  5. slash 127
    Alright I'm waiting in line at DMV should be about perfect timing
