Pilot RC Products Carbide piston drill set with hand drill. Sizes included 1.0mm, 1.2mm - 2.0mm in .1 increments. Features: •Bearing raced anodized aluminum hand drill. •Same size body of each drill bit makes for easy changing with no need for chucking up or down. •Compact crack resistant plastic bit caddy and carrying case. •Precision Japanese carbide. Super sharp accurate holes. No need to push into hard surface risking bent bits or un precise hole. •Because the drill bits tips are razor sharp and due to the small diameter Pilot RC Products recommends holding piston up from surfaces when drilling to avoid bit damage. •Made in Japan Page sale $24.99 Dealer inquires please contact: pilotrcproducts@gmail.com Source Pilot RC Products: https://pilotrcproducts.com/collections/frontpage/products/pilot-piston-drill-set-w-alum-handle
