Copied from the manual: -------------------------- Rebind Process 1. Ensure that the transmitter and vehicle are both turned off. 2. Using the supplied Bind plug (which looks like a standard receiver plug with a short wire loop installed), insert the Bind plug into the receiver slot labeled BIND. When you look down on the receiver slots, it is the slot farthest from the LED, and nearest to the corner of the receiver. Note: You do not need to remove any other plugs to rebind. 3. With the bind plug installed, turn on the vehicle. Notice the LED is now blinking. 4. You are now ready to turn on the transmitter. You should notice on the back of the transmitter a similar blinking LED under a translucent cover. 5. Both the receiver and transmitter LEDs will stop blinking and be on solid, indicating that they have bound themselves together. 6. Turn off the vehicle and then the transmitter. 7. Remove the bind plug from the receiver. 8. Turn on the transmitter and then the vehicle to ensure operation. If the transmitter does not control the vehicle, please repeat steps 1--7 above. If after several attempts you are unsuccessful, please call Horizon product support. 9. The bind process is complete. Your vehicle’s radio system is now ready for use
I'm pretty open. I know you're a fuelly, and I'm into electric, so anything electric related. Or I REALLY need a metal, center-diff ring gear and pinion for a Kyosho Inferno MP5, any other parts for the MP5, or a set of 1/8 scale paddle tires/wheels, or a good 2200mah 3s lipo (25c or better). What do you have that you could part with?
I might be able to make it next Saturday. Won't know for sure until it gets closer to the weekend. I'll let you know either way by next Thursday.
JRock, I'm coming into Medford today. Give me a call and let me know if you're available. I'm not set on any time, so I'll work around your schedule if I can. 541-218-0512.
