Turned the rear cac derlins around and used jun fac wheel spacer sleeved wheel nuts to hold the outside wheel to the axles, worked out good
Thnks, I might black this one out too, that way I can swap beds and rear wheels with the crew cab, so I can have a crewcab dually
Im thinkin its gonna need to build some big arse cow killer bumpers, and maybe some of those fancy dually wheels and a headache rack, possibly scale 8" stack
Do you have a pic of that? sounds like a cool setup. The rear fenders lok like they are coming out nice. with all the work on the bedsides are you going to do a drop bed also?
Do you have a pic of that? sounds like a cool setup. The rear fenders lok like they are coming out nice. with all the work on the bedsides are you going to do a drop bed also? [/quote] I havent taken any pics of the rear wheels, hard to get a good pic, its def getting a drop bed and opening tailgate, as well as interior and maybe crawlerbubba has talked me into an ext cab....thanks for checking it out and ill have some updates tonight
Today I took the stock hilift tires off and swapped in some 1.9 flatirons, then I took the truck out and tied it to a big arse rock to see how much better it pulled with the duals, and found that even with all the tamiya leafs in the rear the rear axle wrapped so hard you could see the pinion touching the ground, so I built a trac bar that mounts to the highest shock mounting hole on the axle and mounted a bracket to the frame right before the back of the cab, now it has limited axle wrap and full articulation and 3.2 inches of tire on each side.......this thing hooks way harder, I drug the 6-10lb rock about 3ft,and it was pullin the right front tire off the ground......pics will be up tonight
It's very easy really. Just upload your video to YouTube first and then use the YouTube button on the left side of the second row of buttons here: ^ Paste the YouTube URL (address) from your browser in between the tags like this: [ youtube ]h t t p://w w w. Your YouTube address goes here[ /youtube ]
