Description We’ve had numerous requests for an ESC Cage for the #3355R version of the Traxxas VXL-3S ESC since the mounting tabs have been reported to us as weak. Why risk potential damage to your $220 (SRP) speed control when the RPMoption is an inexpensive piece of insurance that will prevent those tabs from ever being a problem? Our solution is a simple, yet strong and effective one. We eliminated the use of the two mounting tabs on the ESC in favor of a complete cage system that solidly locks the ESC in place using RPM indestructible nylons. Our ESC Cage is the most effective, durable and best protection for your speed control possible. By completely surrounding and capturing the VXL-3S ESC, damage from broken tabs and ejection from the vehicle has been completely eliminated. The RPM VXL-3S ESC Cage works perfectly even if one or both mounting tabs on the ESC have already been broken or cut off! Now there’s no reason to rely on unpredictable adhesives or zip ties to retain your speed controller when our ESC Cage will lock it in place with 100% confidence each and every time! Each RPM ESC Cage is made from our incredibly strong, ultra lightweight blend of engineering grade nylons and factory-backed by our industry-leading limited lifetime warranty. RPM molded products are made with pride in the USA! Tech Notes: RPM VXL-3S ESC Cages are designed for the Traxxas VXL-3S ESC (Traxxas #3355R) only. While our ESC Cage will fit a variety of applications, they have been tested and only guaranteed to fit the following vehicles in stock form only – Stampede 4×4, Slash 4×4, Slash 2wd & Rally. Also fits the following vehicles as long as Traxxas #3725 Mounting Plate (stock item on VXL models) is used – Rustler, Stampede 2wd & Bandit. Also available in Black color. ESC cages and other chassis accessories are available here: http://www.rpmrcproducts.com/product-category/chassis-components/chassis-accessories/ Source RPM Products: http://www.rpmrcproducts.com/shop/c...c-cage-for-the-traxxas-vxl-3s-3355r-esc-blue/
