Welcome to the future of tire gluing tools. Assault RC product designer Roger Wendling outdid himself on this magical piece of tooling to help you reduce the mess and giving you the best shot at getting the needed amount of glue in between the bead of the tire and the rim. The Revolver Gluing Jig spins on a ball bearing turn table to eliminate the stress of the pulling the tire bead back evenly. By simply putting the top piece on the and twisting it a 1/4 turn you evenly open the bead up in a matter of seconds with equal amounts of pressure all the way around therefore when releasing the top after applying the glue you eliminate most of if not all of the risk of the tire lifting and warping giving uneven side walls. After twisting the top off you pull the tire out, put a band or tape around the bead for pressure and let it sit. We assure you that this is one of if not the easiest way to glue 1/8 buggy tires you have ever tried. We do recommend you clean and prep the bead surface of your tires and wheel prior to gluing, so far we haven't figured out how to make our jigs do that work for you. But the gluing has now become easier and more consistent than ever before. Whats Included: 1 - Tire Gluing Jig To learn more or buy go to the Assault RC website here: https://assaultrc.com/assault-rc-revolver-series-tire-gluing-jig/
