1/4 Scale Pavati R/C Power Boats!!!
Discussion in 'Power Boats' started by Golden Child, Feb 3, 2014.
    The jet drive unit will be for the sprint boat hull to come later. As for beveled gears, the reason isn't to reduce the inherent whine, but to accommodate the different degrees on the input and output shafts of the v-drive itself. So, not beveled like a car gear-drive, but slightly beveled on edge. see Below...
    This is a HALLCRAFT-MENKENS V-Drive unit typical for drag racers. You can see the handle on the back side that is a F-N setup to disengage the drive while idling. To engage the drive you actually need to shut the engine off, put the v-drive box in gear, and fire up the motor (in gear!), to begin your run.
    These are the gears inside that drive unit. This pic shows the back side of the gearset. Notice the lower gear shaft is angled down. This is done by beveling the gears on edge (conical). This can be accomplished also with straight gears, and U-joints attached to the input and output shafts, but that robs power and adds more spinning parts. More parts=more potential for failure. Milling-out a case to hold this setup is quick and easy. However, making beveled gears isn't. And since I need to do this after-hours when the machines are is less use, time is of the essence. So if I can't find the gears I need, I'll have to go with straight and the u-joint setup.
    l8rg8r likes this.
  2. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    That mini flat Ferrari-style 12 cylinder sure sounds sweet! Thanks for posting.
  4. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    I agree if I hit the loto I'm gonna find me one and build a 1/4 scale cracker box with that in it might pirate one of golden child's ideas and go with a v drive
    It seems to me that it sounds quite like a actual Ferrari engine.
  6. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    I agree put that in a cracker box with a set of Bassett headers that would be sweet
    Now if the guy who made that engine would just make a mini Ferrari car chassis... :)
  8. Golden Child
    OOOOHHH! Bassett Headers! Yeah. Gotta TIG up a set of those, wet of course, when I design the sprint hull :D
  9. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    A 1/4 scale sprint with 1/4 scale super charged v8 and Bassett headers that would be grate if I don't hit the loto might have to hit a liquor store lol that would be awesome though now I got to go find my ski mask
  10. Golden Child
    LMAO!!!
  11. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    here is another engine option for ya
    GPS likes this.
    That's a nice motor, good find. You know what I noticed? All the engines are longitudinally mounted instead of transverse mounted. I'm sure that this is to make the already complicated drive system simpler, but a transversely mounted motor would improve the torque steer which you can see when the guys revs the motor on the stand.
    Are there any boats with transverse mounted motors?
  14. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    Ah, good idea. Counter rotating motors should help with the torque. You will have to make sure they are in sync though won't you?
  16. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    Oh yeah synced and tuned and I would prefer to run them into twin props if your gonna run duel engine might as well address the prop walk issue while your at it
    What is prop walk?
  18. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    Under hard acceleration the stern of the boat runs out to the side because the prop is walking sideways it becomes more of a issue as the hp and prop size go up
    Ah. So dual counter-rotating props would help, or completely eliminate that.
  20. l8rg8r
    l8rg8r Registered
    Caldwell idaho
    If it doesn't eliminate it it damn near does
