This is a pretty large airwolf, the fuse from nose to tail fin being 1790mm long. Once you get the box, you will know its huge. And it does come with a lot of goodies. You can set this helicopter up in no time with nothing but allen keys, screwdrivers and a little bit of glue to get some scale parts on that could be damaged easily in transport if prefitted. This scale helicopter comes with a complete scale mechanic! Only electronic components are needed! 12S 5000mAh Lipo battery, 30C + 700 size standard cyclic and tail metal geared servos, not HV equipment needed Align 750MX 530KV Motor HML75M01 (or same size and KV class, no lower KV recommended, main shaft needs to be equally long!) 3 Axis Gyro suitable for scale helicopters (e.g. Skookum 720, Bavarian Demon X) 7 channel RC system (electric retract system is included and requires aux channel for control) 120A HV ESC (govenor recommended but not necessary) Roban Website: http://www.robanmodel.com/cms/index.php/rc-scale-heli-compactor/airwolf-800-size
