New Version of The Thomas Sherrer Long Range System - TxRx700 Lite
Discussion in 'News' started by GPS, Oct 23, 2014.
    Preorder today and we start shipping on the 27th of November.
    TxRx700 Lite is the favorite choice for everyone who want a quality long-range system. Scherrer UHF have for many years been the symbol of quality and with the TxRx700 Lite, you get the Tx700 Lite with an Tx700 NR for a super price.
    The Rx700NR is a small and very light receiver with a sensitivity of -102dBm and an optimized input filter so it can co-exist with strong 2.4 GHz on board video transmitters. The RX comes with a wire antenna mounted directly on the unit.
    RX Specifications
    • External firmware upgrade port
    • Running LED
    • Completely new software
    • Selectable PPM/PWM (S-Bus planned to come soon) upon boot.
    • 9 servo channels
    • PPM output (also called SUM signal)
    • Rssi output 0.5 to 3.3V from min to mix
    • Supply voltage 4-10 Volts
    • Supply current RX alone 18mA at 5V
    • Possible to upgrade to MCX connector
    • Wideband frequency hopping system
    • Uses 433 to 440 MHz ISM licence free band
    • User firmware upgradeable
    • Wide user temperature range -40C to +70C ambient
    • Weight 8 Grams
    • The receiver board is 26 x 53mm.
    Tx Specifications
    It comes packed with all the well known features and a lot of new such as
    • Support Fixed/Variable PPM input
    • Futaba input, all up to 12 channels
    • Head tracker input
    • AUX input (for option boards)
    • Option board port
    • Output power switch
    • Firmware update port
    • Status Led
    • Military standard input plugs with screw protection
    The TX700 comes in a new design that reduces the height dramatically.
    It has also sequential fail safe, that lets you store a fail-safe pattern of 3 interactions when it hits fail safe. Through the firmware port you can access TSLRS debug tools for viewing amounts of fail-safes, blocked channels, diversity performance and much more (TSLRS USB programer needed).
    http://www.tslrs.com/txrx700lite-bundle-p-112
