The PS350 Dual Output Power Supply is capable of up to 350 watts of output between two power ports, allowing you to run two different chargers at once. Twin cooling fans dissipate any heat build up and the all aluminum case is designed to take years of daily use. The PS350 features an input voltage selector switch for both 110v and 220v, allowing greater flexibility. MSRP: $89.99 Specifications: Dimensions: 215 x 94 x 58mm Weight: 2.45 lbs Input: 110-240VAC Output: DC 14V 25A Max Output: 350W Power Cord: USA Read more, see photos of the power supply and order via the source link. Source: http://www.venom-group.com/Store/Chargers/PS350-Dual-Output-DC-Power-Supply
