Pre-Order Open. This is a pre-paid pre-order 67 piece B64 Upper Titanium Screw Set. Products expected to ship March 10-15. Schelle premium Titanium screws are made of Grade 5 Titanium Alloy (commonly known as 6Al-4V) with a bright machined finish to give your car that pure racing look. Unlike Grade 2 known to be used by other brands, the Grade 5 Titanium alloy is the most desirable, giving 40% lighter weight and corrosion resistance compared to steel. The Schelle B64 upper set of 67 screws strategically removes kit steel screws from up high above the chassis, which lowers the CG and improves handling. All chassis bottom screws are not included in this set. M3 screws only (no swaybars or set screws, no motor screws). B64 Titanium Upper Screw Set: 1. Premium Grade 5 Titanium Alloy screws with bright machined finish. 2. 67 pcs. set comes in a re-usable Schelle snap case (chassis plate screws not included). 3. 17g weight savings. 4. For B64 and B64D kits. Set packaged in 3 bags (front suspension/steering, chassis and gearbox, and rear suspension). ** Pre-Tap all holes with a steel screw or M3x0.5 tap before installation.** Screw list: M3x6 BH- Carbon Servo Mount (3), Front Bumper (1) M3x8 BH- Steering Servo Mounts (4), Ackermann Plates (4), Front Chassis Brace (2), Center Cap (4) M3x10 BH- Gearbox and Tower (10), Motor slide (2) M3x12 BH- Steering Block Bushings (4), A, B, C, D Plates (8) M3x14 BH- Steering Rack (2), Wing Mount (3), Rear Chassis Brace (1), Rear Shock to Arm (2) M3x16 BH- Front Shock to Arm (2) M3x20 BH- Front Tower Standoffs (2), M3x24 BH- Rear Tower Standoffs (2) M3x6 FH, Front Body Post M3x10 FH- Front Top Plate (6), Rear Chassis Brace (2), Wing Buttons (2) Not included: Motor screws, Chassis bottom screws. M2.5 screws. Source (Schelle): http://www.schelleracing.com/Schelle-B64-B64D-Titanium-Upper-Screw-Set-67pcs-SCH1123
