REDRC: Team Orion Weight Transfer System LiPo Battery
Discussion in 'News' started by GPS, Jan 26, 2012.
    Team Orion have introduced the WTS ‘Weight Transfer System’ in combination with a World Champion winning Carbon Pro 90C 4000mAh battery. Weight distribution is an important factor in the setup of the car and racers move the battery forwards or backwards to change the weight distribution. The problem is that the size and disposition of current batteries limits the effectiveness of this setting. To remove this limitation, they have developed a new battery case that uses shorter cells and is equipped with three compartments to fit weights. Thanks to this you can not only modify the position of the battery, but also its total weight and the disposition of that weight within the battery case. For perfect installation in your car, the Carbon Pro 90C WTS battery features two connector positions. This also allows you to shorten your ESC cables for even better efficiency. Furthermore the battery has switched battery polarities between front and rear to avoid misconnections when the battery is turned.
    Read more and see photos of this clever battery design via the source link.
    http://www.redrc.net/2012/01/team-orion-weight-transfer-system-lipo-battery
