These new pocket sized Centro rotating ride height gauges are a must have for any racers pit box. Manufactured from Swiss 7075-T6 aluminium these small, simple compact designed gauges range from 15-20mm and 20-30mm increasing in 1mm increments by twisting the can counter-clockwise over the cleverly designed internal ball. It’s small design will allow you to measure the ride height of your chassis perfectly every time, anywhere under your chassis. If you are looking for more scope for your gauge and optional 5mm aluminium foot is also available that can be used in conjunction with the gauge. Read more and see photos of the gauges via the source link. Source: http://www.redrc.net/2012/01/centro-rotating-ride-height-gauges
