RCPROPLUS Spring Lock Soldering Station - A Main Hobbies
Discussion in 'Electronics and Electrical' started by GPS, Apr 1, 2016.
    The RCPROPLUS Spring Lock Soldering Station takes the RCPROPLUS soldering station design to the next level. By replacing the alligator clips, with spring loaded locking heads you get a more secure hold on the item you are are trying to solder without damaging the shielding, along with the ability to hold 6 to 16awg size wire. Plus, the addition of thumb screws on the locking heads allow you to easily adjust the position of the head without the use of tools.
    By combining this updated locking head system with the simple yet ingenious low profile tri-pod base and adjustable horizontal stabilizer bar, you get all the benefits of the previous model, with improved functionality. Also, the stabilizer bar can be rotated over 180°, making the bottom side of the wires the top! Never worry about holding steady to create the perfect solder joint again, the RCPROPLUS Spring Lock soldering stand will do it for you.
    Price: $39.00
    Features:
    • Spring lock wire clamps work with 6 ~ 16 AWG wire
    • Simple, low profile tri-pod design with rubber grip feet
    • Highly adjustable stabilizer bar and clip positions
    Product / Purchase Page:
    http://www.amainhobbies.com/rc-cars...ing-lock-soldering-station-rpprca1618/p478930
