The latest JR transmitters featuring DMSS Dual Modulation Spectrum System* (DMSS), the 2.4GHz protocol developed by JR, is now available on select radios. This new transmission protocol offers high-speed response and high resistance against RF noise. The XG6, XG8 and XG11 include all the advantages of the genuine JR frequency system, plus the kind of legendary high-end software attention that's made JR famous. Each transmitter has full telemetry features with receiver voltage standard on all DMSS receivers, a high-resolution graphic LCD display, easy 3D jog dial input, airplane, helicopter and glider program options, advanced digital trim, touch select functions and much more. No matter what kind of airplane, helicopter or glider you want to fly, there is a JR transmitter designed to enhance your control and deliver an evolutionary level of precision. JR XG6 Key Features • RG631B 6-Ch DMSS 2.4GHz Receiver • Micro SD Card Support (Micro SD card required) JR XG8 Key Features • RG831B 8-Ch DMSS 2.4GHz Receiver • SD card slot for data sharing, storage and updates (SD card required) • Optional telemetry sensors available • Stick tension and spring adjustment JR XG11 Key Features • RG1131B 11-Ch DMSS 2.4GHz Receiver • SD card slot for data sharing, storage and updates (SD card required) • RA01T Remote Antenna • Optional telemetry sensors available • 5-point mixing curves with midpoint adjustment • 3-Axis gyro remote sensitivity adjustment • Multiple applications for stick position switch • Balance function for multiple servo setups Read more and see photos of these three new JR transmitter radios via the source link. Source: http://www.horizonhobby.com/webapp/wcs/stores/servlet/SearchCmd?searchKeyword=dmss&filterTerm=parentcategory:R&searchType=productgrid#nav=ft=parentcategory:R,type:catalog,beantyperoductBean,category_radio_systems:Aircraft%20Radios/:kw=dmss/:st=/:ct=3/:sp=0/:cp=1/:ip=9/:
