Flight Simulators
Discussion in 'General Discussion' started by Golden Child, Jun 17, 2012.
    I am starting this thread because I have found some cool additional add-ons for one of my sims ;D
    Add-ons for RealFlight G4.5, specifically new aircraft models can be found at...
    http://www.knifeedge.com/forums/downloads.php?do=cat&id=332
    New and custom airfields can be found at...
    http://www.knifeedge.com/forums/downloads.php?do=cat&id=330
    Download the new models/airfields you want, then import into RealFlight by following the steps below ;)
    Q. HOW DO I INSTALL CUSTOM CONTENT?
    A. When you have downloaded the file(s) you want from our swap site, load RealFlight. Select the "Simulation > Import > G3X" menu item in G3.5 or "Simulation > Import > RealFlight Archive" in G4 and G4.5. In the import dialog box that appears, locate the file you downloaded and open it. RealFlight will import the file. In G4 and G4.5 you can select more than one file to import at one time. Do not attempt to put custom content in RealFlight's data or documents folders; this will not work.
    If you have any trouble with this, just post your issues here and I'l try to help walk you through it. Enjoy!
    Downloads for other versions of RealFlight can be found here:
    Hope you all enjoy these ;D
    ALSO: An excellent thread for Phoenix RC Fight Simulator upgrades from version 3 to the newest version 4.0.k was started by w00d in this thread http://southernoregonrc.com/index.php?topic=928.0
