DIY: Simple Variable Pitch for Brushless Motor
Discussion in 'Multirotor' started by GPS, May 6, 2013.
    With a brushless motor and a TRex tail rotor mechanism I could assemble a simple variable pitch system. I measured and it generates 700g with the TRex 500 tail rotor blades.
    I tried the Trex 250 blades from the main rotor but although they are longer the thrust is smaller, just 400g. This is probably because the motor doesn't have enough torque.
    This could be used for a variable pitch quadcopter or with an airplane.
    Specs:
    Motor: Hextronik DT750
    ESC: Plush 25A
    Battery: Turnigy 2200mah 25C
    Tail rotor: HK-500GT
    Wood to support the tail mechanism: 38mm tall
    http://diydrones.com/profiles/blogs/simple-variable-pitch-for-brushless-motor
