Caterpillar (CAT) S60 Rugged Smartphone With Built-In FLIR Lepton Camera
Discussion in 'General Discussion' started by GPS, Feb 18, 2016.
    The new Cat S60 features a built-in thermal imaging camera from FLIR, the global leader in thermal imaging technology, that puts the heat sensitive technology in a smartphone for the very first time. Ideal for builders, electricians, emergency services, utility workers and so many more, the thermal camera can be used to almost endless effect, saving time and money by detecting heat loss around windows, spotting moisture and finding overheating appliances.
    As with all Cat products, the S60 is also an extremely tough rugged smartphone. Featuring a Corning® Gorilla® Glass 4 touchscreen, it exceeds military specifications and is designed to withstand drops onto concrete from up to 1.8m. The rugged credentials of the S60 also make this the world’s most waterproof smartphone, able to handle depths of up to five metres for one hour, turning it into a reliable underwater camera.
    Cat S60 key features:
    • Thermal imaging camera, powered by FLIR
    • Strengthened Die Cast Frame
    • Drop proof to 1.8m, MIL Spec 810G
    • Super bright display (typical 540 nits), Gorilla Glass 4
    • 4.7” HD capacitive multi-touch with auto wet finger & glove support
    • Optimised battery performance (3800mAh)
    • High quality audio experience (>105dB)
    • Underwater 13MP main camera with dual flash, 5MP front-facing camera
    • 4G LTE
    • Snapdragon 617 Octa-core processor
    • 32GB ROM, 3GB RAM
    • Android Marshmallow
    Source (Catphones):
    http://www.catphones.com/
