I have scx10 dingo kit my axles wiggle at the y link and make clicking noise I've tried to tighten but nothing is working any suggestions
If I'm not mistaken that hole bores itself out after use. If you bought it rtr it should come with the stuff to 4 link it and your problems will be gone
i put one of those kits together not that long ago! just make sure the axles go together w/o any force! i tryed to muscle mine together and almost broke the housing! just make sure everything is lined up right also where the pinion comes out of the axle make sure its pulled out all the way! i had to but an alen wrench in the and use both of my fingers and pull as hard as i could to make sure it came out so everything would line up right!
does it have extra plastic links included? if it does just try different links until the driveline is at a good angle
You want the nub for the driveshaft as close to pointing to the tranny as you can get it if you didn't know
