REDRC: QTEQ Power Terminal - Smart Design
Discussion in 'News' started by GPS, Dec 25, 2011.
    QTEQ have released what they are calling the Power Terminal, which is essentially a means to connect the cables to your motor without the need to solder the joint. It consists of 3 parts, a device side part that is soldered to the motor’s power connections, a cable side part which is soldered to the cables and a set of 3 M2×10 screws that allow you to securely attach the wires to the motor. The end result is that the conductivity is comparable to that of directly solder systems.
    Read more and see some photos of this innovative brushless motor connector system via the source link.
    http://www.redrc.net/2011/12/qteq-power-terminal
