Pulse Ultra Cube - Being Square Never Looked So Good. Enter the all new Pulse Ultra Cube - the very latest in innovation, pack layout and undeniable speed. With the all new Cube design, Pulse Ultra has redefined FPV specific LiPo technology, offering an ultra compact layout for all manners of FPV racers. This design allows all new mounting options and better CG - all with a better fit & aesthetic to your machine. With a key focus on aerodynamics, the Cube has a reduced surface area for high speed flight, offering the ultimate in FPV speed. Add in the 95C discharge rate, the Pulse Ultra Cube has amperage to spare when you need it the very most. Simple, functional and ready to rock - step up to the Cube and push your quad like never before! Features: - Insane 95C Discharge Rate - Dedicated High Performance FPV Racing Pack - Industry Known Performance - Full (90) Day Warranty Period - 5C Charge Rates for Ultra fast Charge Times - Pre-Soldered XT60 Connectors - Light Weight & Low Cost - Pulse Ultra Quality & Performance - Extended Cycle Life Operation Specifications: Capacity: 1350mAh Configuration: 4S1P / 14.8V / 4 Cells Discharge Rate: 95C Max Burst Discharge: 190C Net Weight: 162.5g (+/- 2g) Dimensions: 49mm x 49mm x37.2mm (LxWxH) Balance Lead: JST-XH Power Lead: XT60 Source HeliDirect: https://www.helidirect.com/pulse-1300mah-4s-14-8v-95c-square-lipo-battery-with-xt60-plug.html
