FLOW-MAX™ ALUMINUM COOLING BODY FLOW-MAX Air hole is designed after various tests. Make the best motor condition, maximum cooling. HIGH RPM SUPER LOW-FRICTION BEARING Their special construction with a Super Low-Friction steel inner shield on the side maximum protection against the elements while optimising the drive train efficiency compared to all-metal shielded ball races. ADJUSTABLE TIMING SYSTEM Open the end bell, you can change to motor timing. Motor timing range is -10 ~ +10deg. DUAL-PLUG SENSOR CONNECTOR HOLES FLETA ZX 8 Motor is dual-plug sensor connector holes. You can change the sensor position according to car layout. INCLUDED FLEXIBLE SENSOR CABLE Super Flexible Sensor Cable for each motor category. Connect strongly and bent naturally. All black color design. 4-POLE-8 MAGNET "STAGGERED POLE" ROTOR New FLETA ZX8 Low Cogging Torque Version 2050KV motor adopted the innovative 4-poe-8 magnet "stagged pole" rotor Can easy driving and will reduce the ESC`s damage. Source Muchmore Racing: http://www.muchmoreracing.net/product_view.php?pidx=1529
