this is a crawler I threw together with parts and help from crawlerbubba, the chassis is mostly scx10 with a custom front clip and shock mounts, its running gmade r1 portal axles and rc4wd 110mm coilovers, as I said before it was thrown together, so I am wanting to rebuild/rework some of the exo and move the rear shockmounts up to the truggy frame, here are a few pics of the initial build and some from tonight as she sits
Ok, this thing is a mess, i def need to finish the front section of the frame as you can see its just a welded mess, the suspension links are all missmatched and I also need to backhalf the rear frame section and rework the rear tubing to be more truggylike, the first go round was my attempt at a truggy with bedsides but im not happy with that decision at all.
Ow ya, its a runner, im just wanting to go thru it and make it solid, its still in the same unfinnished shape it was in your shop, I just threw all the electronics in and ripped it around untill I put it on the shelf, a month ago.....i really need to go crawlin
Bought a new cab and Got started on the dash for the truggy, also built a back cab and have started on some racing seats,guage cluster and floorboard
Ended up makin a cowl hood and started tuckin in all the electronics under the dash and hood, the cowl hood gave the esc room and a good cool air intake, with the fan on you can feel the air getting sucked into the cowl hood
Thanks, I had to notch the cab corners and roof just to make it easier to fit the cab into the exo, I ruined the paint on the orange one and it was bothering me
Excellent build yotapane! Did I understand that correctly, you fabricated the dash from sheet polystyrene plastic?
