EB410 REAR LOCKING HINGE PINS, TITANIUM 1 PAIR Titanium locking/captured hinge pin set with 2mm hex head for the EB410. Eliminates the problem of the rear hub hinge pins sliding out of the arms during impacts. Securely holds the hinge pins and hubs in the rear arm, thanks to the captured pin and lock nut design. NOTE: a 3mm drill bit or reamer is needed to open the front small hole of the arms for the pins to pass through. 1 pair of titanium pins and steel locknuts. $14.95 MSRP http://www.exotekracing.com/eb410-rear-locking-hinge-pins-titanium-1-pair/ EB410 STEERING RACK, 7075 Precision heavy duty 7075 alloy steering rack for the hot EB410. Reinforced design minimizes any extra cut outs to increase strength, yet only weighs 6gr. Gives your EB410 a smooth factory racing look thanks to the polished surfaces and our special glossy navy blue anodizing. $18.95 MSRP http://www.exotekracing.com/eb410-steering-rack-7075/ EB410 HEAVY DUTY D BLOCK, STEEL http://www.exotekracing.com/eb410-heavy-duty-d-block-steel/ EB410 BRASS C BLOCK, 18GR http://www.exotekracing.com/eb410-brass-c-block-18gr/ Source Exotek Racing: http://www.exotekracing.com
