The next generation of rear wings is here, developed and manufactured by JConcepts Inc. The S-type wing includes options not yet seen before on a 1/10th off-road rear wing. An extended rear gurney lip makes tuning that much better for more grip on the loose surfaces while running the latest generation in off-road. The base of the wing design is built on the popular Aero wing but with new additions which make the wing more durable, more adjustable and ultimately a great tuning piece. The S-type wing is a direct bolt-on piece for the Team Associated B6, B6D | B64, B64D. The wing features a long chord construction with revised section to incorporate some reinforced ribbing in the vertical plane below the over-hanging gurney. Cut-lines and dimpled locations are positioned throughout for trim and tuning options. The dimples in the rear can be reamed to expose larger holes which serve as pass-through for circulating air and helps the vehicle maintain its position during long flight jumps. Features: Innovative design, durable material Industry first, forward gurney option Clipped rear corners minimize breakage Large openings for tire clearance and expansion Dimples for pass-through hole tuning Pro-level height and rake angle 1/10th off-road wizardry Source JConcepts: http://www.jconcepts.net/shop/aero-stype-b6-b6d-b64-b64d-wing
