BlueROV - ArduSub Powered Underwater Rover
Discussion in 'Robotics' started by GPS, Mar 3, 2016.
    Product Description
    The BlueROV is an unassembled kit with frame, watertight enclosure, thrusters, and speed controllers. The electronics are up to you – open source software is available. Hardware/software experience required. It uses six T200 Thrusters to provide six-degree-of-freedom control allowing you to point the ROV in any orientation to film anything, grab anything with a simple robot arm, and have a lot of fun!
    Features
    Frame
    • Thick laser-cut acrylic side panels with extra holes for future expansion and features
    • 100% glue-less frame design using 20mm aluminum T-slot tubing and custom aluminum stand-offs
    • Tough and machinable Delrin parts for durability and easy modification
    • Watertight enclosure is secured with two fabric straps for quick removal
    • Lots of room for expansion and additions – extra holes allow the addition of buoyancy foam or ballast weight
    Watertight Enclosure
    • Cast acrylic watertight enclosure with lots of space – 12″ long and 4″ inner diameter
    • Custom CNC aluminum o-ring flanges provide precision seals and modular end-cap options
    • Laser-cut cast acrylic end-caps for optical clarity and strength
    • Custom CNC aluminum sealable vent allows the end-caps to be installed without rods or screws
    • Custom cable penetrators designed for thruster cables make it easy to pass thruster cables through the end-cap with a watertight seal
    • Laser-cut Delrin electronics and battery shelf inside with mounting holes for APM autopilot, Raspberry Pi V1 or V2, camera, speed controllers, and battery
    https://www.bluerobotics.com/store/rov/bluerov-r1/
    ArduSub:
    http://ardusub.bluerobotics.com
