Description Finally, a rear bumper for the Traxxas Stampede 2wd is now available that combines awesome scale looks with performance that works! Our new rear bumper is designed to protect the rear of the chassis, the motor and the body, all while still allowing the use of a stock Traxxas Wheelie Bar (Traxxas #3678 – not included). Additionally, if you decide to run without the Wheelie Bar, our rear bumper is so versatile, it’ll adapt and allow either configuration. Our rear bumper for the Stampede 2wd consists of a scale bumper that uses design elements from many of today’s top full-scale bumper manufacturers. We start with an upper tubular shape, followed by faux stamped sheet metal filleted holes, a scale license plate area and with a final touch of a pair of scale 3” square openings for 5mm LEDs. That’s right, our bumper allows you to install your favorite 5mm LEDs (not included) to be used as taillights, reverse lights or any other use you can imagine! The RPM bumper supports are designed tough, with serious impact absorption characteristics built in. With the use of an RPM Rear Bumper Mount (RPM #80902 or #80905 – not included), the protection for the motor becomes nearly indestructible! Each RPM Rear Bumper is made in the USA from our engineering grade nylons and is backed by our limited lifetime warranty against breakage. Tech Notes: RPM Rear Bumpers for the Traxxas Stampede 2wd require a bumper mount (either a Traxxas #3677, RPM #80902 or RPM #80905 – not included) or a Wheelie Bar (Traxxas #3678 – not included) to install the RPMRear Bumper. Some body trimming may be necessary to clear the bumper supports at lower body height settings. Tested and guaranteed to work with Traxxas #3617, #3617R & #3617X bodies with minimal trimming required. Other bodies may require additional trimming beyond what is mentioned in the instructions supplied. Any standard sized, round 5mm LED’s (not included) will work with RPM bumpers. Quick Notes: – works with or without a Wheelie Bar (not included) – scale rear end protection unmatched by anything else available – compatible with Traxxas or RPM Rear Bumper Mounts (not included) – integrated 5mm LED sockets for lights! (LED’s not included) – available in Black or Blue Source RPM Products: http://www.rpmrcproducts.com/shop/b...ack-rear-bumper-for-the-traxxas-stampede-2wd/
