$249 Pixhawk Compatible Laser Altimeter - SF11
Discussion in 'Electronics and Electrical' started by GPS, Feb 10, 2016.
    SF11/C is a long range (0 ... 120 m), light-weight, laser altimeter designed for above-ground level measurement from UAVs (multi-copter or fixed wing).
    Typical applications:
    • Warning of FAA height limits.
    • Precision photography.
    • Terrain following.
    • Assist with takeoff, landing and hovering.
    The SF11/C provides accurate and fast altitude (AGL) measuring capability, regardless of terrain. It includes digital (serial and I2C) and analog (12 bit) outputs along with a micro USB configuration port.
    • Easy to configure using the built-in menus and LightWare Terminal software
    • Fully calibrated and ready to run
    • Complete with power, interface and micro USB cables.
    Manufacturer's (Lightware) Website Product Page:
    http://www.lightware.co.za/shop/en/drone-altimeters/51-sf11c-120-m.html
    Will be available at Parallax:
    https://www.parallax.com
    Data sheet attached.
